vandave's avatar
vandave
Hot water heater moving out
I noticed the top of my hot water heater is pulling away from the rv side about 1/4". Any ideas how to move the top of the hot water heater outside frame against the rv? Bought the unit new in 2006. Arctic Fox 30U model.
  • On a prevoius pop-up I had there was a leveling block under the tank. Maybe your has rolled over. On my trailer the screw attaching the block to the floor went into the tank after it rolled over.
  • vandave wrote:
    Thanks. I've tightened the four long screws but there remains a gap at the top.
    Did the top 2 actually tighten?
    There should be NO GAPS otherwise water will get in and cause wood rot, delamination, mold/mildew etc.
    Flush mount means exactly that...FLUSH.
  • Thanks. I've tightened the four long screws but there remains a gap at the top.
  • Frame mounted will have 12 screws to secure it to side of trailer
    Flush mounted will have 4 long screws that go thru brackets (2 on each side top/bottom) to secure it to side of trailer
    Some flush mounts have 1 long screw on each side towards bottom thru a bracket and then have 2 more screws on top from inside
    If you have a frame mounted it would be very obvious when you open outside access door.
    Flush mount you need to look closer when you open the access door.
  • My first thought was rotten wood, only that should be an Aluminium framed rig.
    They are usually attached from the front via several screws into the framing around the water-heater. Have you checked those screws?
