eieiohExplorerMar 29, 2022Hot water heater pluggedMy Atwood water heater has no flow. If I put it in by-pass water flows fine. In run position there is a short flow and then nothing. Any ideas?????
MFLNomad IIMar 29, 2022^^Similar issue...if you have easy access, a much simpler repair. Likely the hot out check valve is stuck/broken.Jerry
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSmelly Water HeaterWater pump?Suburban SW12DEL Water Heater On/OFF switch melts???
