ljedik's avatar
ljedik
hot water pressure relief leaking antifreeze?
I noticed my camper's hot water pressure relief valve is leaking antifreeze today? is that normal under freezing temperatures? I'm in upstate NY.
  • the bypass inside is off, this is on the outside of the camper?
  • I don't know why your relieve would be leaking antifreeze, but if you are filling the WH as part of winterizing, I suggest you put in a WH bypass kit and save yourself a lot of money.
  • Does your hot water heater not have a bypass?
    Somebody must have turned it on and got it hot
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
