- Grit_dogNavigator III
midnightsadie wrote:
be nice if it was a 20amp out let, and I,d not use any thing else on that line. I run my rv ac off one with no problem.
He said it was 20A in his title. - Grit_dogNavigator IIIVery likely yes. I have a less than ideal service to my shop and am able to run the AC on all of the campers we've had off of a 15A service.
But at some point (may not have been the camper AC) that outlet got hot.
I replaced with a 20A outlet (since it is only a few feet from the subpanel, and already on a 20A breaker) and that works like a charm.
Keep the extension cord short. If you're using just your RV cord with no additional extension cord(s), that is the best scenario.
Worst case, it pops the breaker feeding that outlet. No harm, no foul. - way2rollTrailblazerOne of the nice things about an RV is that if something like the heat or AC goes out in your house, you can use the RV. As others said, just run one AC and nothing else and you should be fine. Usually worst case, you trip a breaker. I had a previous Class A that didn't mind a 15A for AC. My current FW prefers a 20A - it will trip a 15A even with only one AC running.
- Johnsonty131ExplorerI’m guessing 120 volt. All my house breakers say 20 also
- bgumExplorerIs your "normal house outlet" 120 volts or 240V?
If it is 120v then yes but I wouldn't run anything else such as converter/charger, fridge, water heater. - midnightsadieExplorer IIbe nice if it was a 20amp out let, and I,d not use any thing else on that line. I run my rv ac off one with no problem.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
