Leeblev
Jan 03, 2014Explorer
Several things:
Is the KIA front or rear drive? If rear, you well may have a problem.
I assume the dealer told you it wasn't towable 4 down. Go to REMCO.COM and see if it is on the list of towable toads.
If it is front wheel drive, you can buy a tow dolly that the front wheels of the KIA will ride on. You must first determine how much your MH can tow (including the weight of the tow dolly)and you will have to do some lighting/brake light wiring as well as installing a breaking device in the car.
First determine how much your MH can tow. Everything else depends on that.
Good luck
Good luck
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
