darsben
Jan 06, 2014Explorer II
Dutch_12078 wrote:darsben wrote:
Almost all automatic transmission vehicles must have the drive wheels off the ground or drive shaft disconnected to flat tow (all four wheels on the ground).
Many automatic transmission vehicles CAN be flat towed either as is or with the addition of an electric transmission lube pump from Remco. Our Toyota RAV4 is just one example of an automatic 4WD that tows quite nicely using a Remco pump. With over 40,000 miles in tow on two RAV's, our pump setup has been completely trouble free. If Remco says the Kia can be pump equipped, it can be towed four down.
Okay, Even though my original response was correct I will modify it almost all unmodified automatic transmissions must be towed with driven wheels off the ground or modified with the possibility of voiding the manufacturers warranty DOES that make YOU FeeL BETTER
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
