tpi
May 02, 2014Explorer
Most converters don't need the batteries in the system. The power is well regulated and will not induce hum in electronics. But check the documentation that came with your converter to confirm. You would not want the disconnect in the same confined space as the batteries.
On this page it mentions no need for battery under the "key features" http://www.bestconverter.com/PowerMax-Boondocker-Converters-_c_154.html
You could also use 120V switch on the converter power wiring.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
