opnspaces
May 02, 2014Navigator III
I would second that there is a main 30A breaker and a sub probably 15 amp converter breaker.
If you have a meter, connect it to the battery while on generator of shore power. Then start flipping breakers one at a time until the meter shows a drop in voltage. At this point the charger is disconnected. Assuming the microwave still works you'll have found your answer. Just don't forget to turn the breaker back in when you're done with the microwave.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
