- RasMouSeinExplorerFrom LowProLockDown
When I find a permanent spot I will get this one.
- CopperheadExplorerKSH Marine beat you to it.
- down_homeExplorer IIQuite some time ago I designed in my head a cage for generators. Design a box of stainless that your unit will fit in, and a removable to from lower flat section, Shield top from rain, hoes in sides or ventilation and access without unbolting to fuel fill and of course starting. A Metal shop will probably charge in the neighborhood of 200.00 250.00. or not.
Design the bolting system to your rv bumper or whatever with a bit of consideration. Otherwise vent a compartment and install a fan and put it inside. Or jsut make sure the door is open and fan is running when generator is running.
Closed up no one is the wiser unless they are cruising through picking targets, which seems to be the case in most instances.
Some hard mount them in pickup beds with and use long cables. harder to manuver around fifth wheel hitch and unbolt something like that, but this is not perhaps the best choice. Some Fifth Wheels and Trailers could be optioned with a generator, perhaps purchasing and installing that unit in the compartment, would be the best of ideas. Cost is perhaps the important first consideration, but replacing a stolen generator will at least double that cost. - Chuck_thehammerExplorer
IBcarguy wrote:
Heavy cable and padlock in my pickup bed. No matter what you use, if they want it bad enough, they'll get it.
1 million percent T R U E..........! - IBcarguyExplorerHeavy cable and padlock in my pickup bed. No matter what you use, if they want it bad enough, they'll get it.
- CopperheadExplorerWhile I do have a .45 in reserve, I am partial to a Remington pump 12 or especially my trusty little Coach double short barrel 12. That Coach is one of the most legal firearms in the country and will ruin a thief's day far more quickly than a .45.
- Route_66_TravelExplorer+2, in 45ACP
- Bigg_AlExplorer
tinner12002 wrote:
pianotuna wrote:
Which may come with free room and board at the crowbar hotel, possibly for a life term.
The lack of respect for life appalls me.kerrlakeRoo wrote:
cable lock and a Glock, and scattering a few empty shell casings near it also helps.
It only appalls you because you can't have a Glock up there! Lol! Actually I'm a Ruger or S&W kind of guy myself!
+1 - tinner12002Explorer
It only appalls you because you can't have a Glock up there! Lol! Actually I'm a Ruger or S&W kind of guy myself! - ctilsie242Explorer IIHere is what I do:
1: Two security chains, metal, high test. Not stuff that is cut at the Home Labyrinth store. I import the padlocks from Germany, as Abus Granit are good. Alternatively, Sobo padlocks are a lot cheaper, but they are decently secure. Recommendation is a "detainer disk" key lock. Yes, Bosnian Bill and the Lockpicking Lawyer can pick those open, but not many people on the street are going to be carrying a pick with them and trying to open the lock up at the right angle to get in.
2: Insurance. If someone wants a generator enough, they will be taking it. Worst case, they will use a cordless angle grinder and cut the handles of the generator.
3: If the claim is big enough, write it off my taxes.
Of course, the best solution is to get an Onan generator. Out of sight, out of mind.
Looking for advice before your next adventure? Look no further.25,176 PostsLatest Activity: Nov 14, 2025
