- YC_1NomadI understand you have a scooter already but often a used one that breaks down is very inexpensive. I have purchased three of them and they were quite new. Both for $500 or less. They have smaller tires so are not good in gravel etc but are perfect for theme park usage or the like.
I carried two of them in the back of my Ford Edge. - Grit_dogNavigator IIIWhy do some of you just tell stories that aren’t applicable or helpful to the OPs question?
- CA_TravelerExplorer IIIOur scooter has very low clearance and this includes the 2 small wheels behind the rear wheels that prevent the scooter from tipping up like on a grade. Check your scooter clearance for the ramps.
- CA_TravelerExplorer IIII use a pair of 12"x90" foldable ramps. With the scooter they fill the back of the car. Make sure you have headroom and depth for the scooter and the ramps. You should have holddown for straps to secure everything.
I also have a non motorized carrier on the back of the car for the scooter but the scooter is inside the car when towed to eliminate dirt and water. Scooter plus carrier weighs about 240 lbs. - dpgllgExplorerI'm fortunate that mine breaks down and fits into front compartment of 5th wheel. I then put it into back of truck to haul when out and about. I have a fold up cover on truck so it is protected.
I am assuming that you have a motor home with toad. One possible option would be a reciever installed on front of motorhome but then how would you transport when out in the toad?
Maybe provide a description of motorhome and toad and someone might have already solved this issue.
Dave - LwiddisExplorer IIIs your front axle weight under max enough to consider a front end rack etc.?
- Dutch_12078Explorer IIIWhen my wife's sister traveled with us for a few years, we carried her non-break down scooter in the back of our then 2002 RAV4 toad. I installed an electric lift that made loading and unloading quite easy. We had to fold down one of the rear seats to make room for the scooter.
- Grit_dogNavigator IIIFront rack with a cover on it is the only option then. It appears anyway.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
