Grit_dog
Aug 21, 2021Trailblazer
JRscooby wrote:
The longer shank will give you more clearance, let you jack tighter. Will also pull more weight off front axle of TV. Lots of other issues, if going to tow that way.Whangler wrote:Super_Dave wrote:
What do you think about putting a front hitch on?
Haven't even thought of it, but would certainly entertain that possibility. Tell me more?
Many think a idiot hitch is the way to go. And for many people and a boat trailer, I would agree. But while you are thinking about it, pull center of TV nose up to the tongue of the TT. What can you see? I would think it might be better to mount the hitch to the end of right frame rail, so could at least see 1 side of trailer.
That said, if one is truly at the physical limits of being able to back a trailer into a tight spot, a front hitch will get it into a tighter spot. Whether it’s based on room for the tow vehicle to pivot, or the angle of jack knife required to get it there.
No question, not debatable. Having the steer axle near the trailer tongue acts more like a dolly than having to pivot the whole tow vehicle to make the trailer go in the right spot.
Whether one has been a professional cab jockey their whole life or a weekend warrior with their first trailer.
Using a front hitch as a crutch for lack of backing skills is an option, but not one that I find to be less difficult conceptually. You still have to stick the trailer where it needs to go without hitting something!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
