bigfatguy's avatar
bigfatguy
How durable/reliable are slideouts?
As I look around at various RV's to eventually figure out what I'd like to buy, one of the designs I really like has a rear-facing slideout. With it in, the bed is a sofa, and if you slide it out the sofa becomes a bed, but if it were to break the sofa would be stuck as a sofa, and I'd have nowhere comfy to sleep.
How reliable are slide-outs? If they do fail, is it possible to manually drag the slide-out out?
I know I'm being paranoid... it's the price of being an engineer...
  • Ours is 17yrs old and while I've never used it, there is a hole for a hand crank (now where the hand crank is...)
  • if it is a sofa bed, you will have no comfy place to sleep, even before it breaks. both of my slides worked fine for 14 years.
    bumpy
  • I'd be more worried about having to sleep on a sofa bed.
    Most I can take is two nights.
  • Think safety. Ours has a manual way if the electric way fails. This is our first slide and have had the same concern. Now i wouldn't have a trailer without one. Extending the width of the trailer is very nice.
  • There are a lot of variables in "reliability". Who the manufacturer is. How often is it used. What materials are used in it's construction.
    I have a 3 slide outs on my MH and never had a problem. They are powered, but there is a method to retract them manually. The premise is that if the unit fails you don't want to drag it out because you might not be able to get it back in and then you are stuck.
    You might want to if there is a procedure for doing what you want to do in the owner's manual
  • Get manuals on the slide. Almost all of them have some kind of override to make them operate when the system fails.
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
