Lessmore
Sep 27, 2017Explorer II
Turbochargers... durability, reliability ?
Some years ago, turbochargers seemed to be considered service items, that may or may not last the engine life of the vehicle. We're thinking of getting a new midsize SUV, that will be able to do light towing (2000-2500 lbs.)that will use either a small V6 or 4 cylinder gas engine, with a turbocharger.
We haven't figured out the make yet, we need to go out check them out, test them, evaluate, etc.
At one time I would not of considered any turbocharged gas engine, due to concerns about durability and expensive replacement if needed.
Are the turbos and related engine parts generally good for the life of the engine...or can you expect to have a lot of work done of them to keep them working ?
Any additional maintenance / service or parts required for the turbo charger on a gas engine ?
Am I missing anything else ?
Also, it seemed awhile ago that before you shut the turbo engine down, it was always wise to sit in the vehicle and let the engine idle for a couple of minutes so the turbo could slow down in rpm and dissipate heat from the bearings, other components in the turbocharger.
Do you still have to this ?
I don't know if any of that is still the case anymore.
Most of the guys on that have turbo gas engines on this forum have the 3.5 liter turbo Ford truck engine (F 150, Expedition, Explorer)...some have the 2.7 liter Ford Turbo V6, etc. These Ford turbo engines seem to be durable, reliable and able to rack up significant miles and I haven't been aware of any issues with them. But are there ?
Now one turbo vehicle we might consider is the Ford Explorer with the 3.5 turbo V6...or other manufacturers...like other American domestic vehicles or some of the Japanese vehicles.
We plan to get an extended factory warranty no matter what. We've never had any vehicles with a turbocharger before. Is it safe to dip your toe in the water ? :D
