subcamper
Sep 16, 2019Explorer II
I had to do this exact thing on our 2004 Rockwood when it was NEW! I had a leak into the storage cabinet at the top of the dinette slide, but only when water got under the topper. Most of the time the topper masked the bad seal on the slide roof by covering it.
This was years ago, but if I remember correctly, there were two brackets that bolted to the slide wall (one at each end) and the topper ends had pieces that slid onto the brackets and were held from moving by setscrews. You had to slide the topper about 6 inches sideways to release it. I think I had to remove one end cap on the topper, and also there was a place to push a Phillips screwdriver into a hole to lock the roller in place so it didn't try to retract and pull the topper. Since you had to slide the topper sideways a little to release it from the brackets, I had to have the slide extended at least halfway so the topper canvas could move 4-6 inches sideways at the slide wall end while still held tightly at the RV wall in the channel above the slide.
Like all slides, beware that there is a lot of tension on the roller and you could get struck by a spinning end bracket if you don't lock the roller.
These are for my slide topper, yours may be completely different.
Steve
Steve
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
