wa8yxm
Sep 16, 2019Explorer III
Takes about 2 seconds with the tree in the wrong place
Removing it was not the problem
Putting it back on was.
That said. it depends on a thing or 3
The "Top" end of the slide topper likely rides in a channel that runs the length of the RV. if you can get the RIB to come out then it's easy to remove (putting it back may be an issue) Be sure to PIN the roller (You will need the manual to figure out how to do that) or bad things happen before you do anythign else
Two removal methods
Once the roller is pinned if you can pull the rib out of the canvas you just remove a few bolts and slide it forward and back and it is off.
IF not.. I opened the channel either "Before" or "After" the slide and then slid it out with the rib in place.... Slid it back the same way and tapped the channel back to close to original
It is a 2 person job for the most part though I can do it alone.
Two removal methods
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
