luberhill's avatar
luberhill
How long will tv run on invertor ?
Ok the guy I bought my MH from gave me an invertor, I plugged it into the cig plug and it came on, plugged the TV into it and it wouldn't turn on ,,,but I started the coach engine and the tv came on with the invertor, shut the coach off and it stayed on..
Worked fine...so I assume the cig plug is on the cranking battery,,,
Wonder how long this will run the tv before it kills the battery ??
The coach has a switch that IF the battery dies you hit the switch and it will start the engine off the two coach batteries...
  • depends. what else is energized by the chassis battery? how many watts does the TV consume per hour? what is the state of the chassis battery? too many variables to give a definitive answer.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 11, 2025
