PackerBacker wrote:
chrizg wrote:
cbshoestring wrote:
I open both hot and cold drains as I am packing up. Doesn't completely drain the tank (I am not pulling the drain plug) but it takes most of the water out of the system. I frequently forget to close them, then I leave a trail on the way out of the CG.
Opening the hot/cold drains doesn't take any water out of your water heater..
Yes it does. That's how I drained mine for years with both the Suburban and Atwood units that I have owned.
For anyone reading this don't get the idea that opening your hot and cold water drains will drain your tank. If may work for one but unless you have water than runs uphill it does NOT work. Hot water comes out of the top of the tank, not the bottom.
