mkirsch's avatar
mkirsch
Nomad II
Jun 04, 2013
How the pro RV transporters tow
If you travel Interstate 90 through Ohio, PA, and NY you see a *LOT* of professional RV transporters moving units East this time of year. I paid close attention any time one passed by and tried to gather as much detail as I could.
1. They ALL run big diesel dually crew cab trucks. Big heavy diesel engine to counterbalance the tongue weight of the trailer, and that long wheelbase makes a great lever arm to maximize the effect. Plenty of "junk in the trunk" to keep the tail from wagging the dog too.
2. The ones headed West for another load all had heavy-duty aftermarket receivers installed on their trucks for maximum weight-carrying tongue capacity. No need for WD bars to prevent overloading the receiver.
3. The trailers they towed were generally far below the maximum capacity of the truck. Tail's not big enough to wag the dog.
4. The trailers they towed were almost always hitched severely nose-down. Good for stability, and not a big deal with an empty trailer on trip from factory to dealer, but hell on tires and springs over the long haul.
Oh, and they *DO* use WD bars in some instances, such as the big park models. Almost all the RV transporters I noticed were using WD shanks to tow with, even if they weren't using the bars on the smaller units.
These guys aren't fooling around with a midsize SUV on 4 P-rated tires with the stock receiver towing at 99% of its advertised factory tow rating. What they do is akin to towing a Radio Flyer wagon with a freight locomotive.
  • Time is money and it isn't their rv.
    Doubt any MFG. would hire someone that showed up with a 1/2, 3/4 or SRW 1 ton tow vehicle........or maybe they would.
  • Most of the ones I have seen that I was fairly sure were transporters were doing 75-80 out on the open highway! :E
  • I saw two new TT's on a low boy flatbed the other day attached to some kind of winching system. The maker doesn't care how they get it there as long as it gets there in one piece.
  • They also routinely exceed the safe towing speed of whatever trailer they happen to be pulling, and buy new tires every other month.
    I've known a couple guys that pulled using single axle gassers, though they eventually move to the diesel duallies to maximize their tow opportunities.
    As a side note, no special license is required to haul RVs in this manner (except for a business license!).
    Nor should they be. For while one RV may be well below the truck's capacity, The next one may be the max. Can't have a truck for every TT you tow. Need a one size fits all. When I drove big trucks. We had loads the varied from 4,000lbs to 40,000lbs. We used the same tractor every time. A pro never knows what the next load will weigh.
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 23, 2026
