DarkSkySeeker's avatar
Jan 15, 2019
How to access the LED strip over my slide out
There is an LED strip tucked over and behind the top of my slide out trim.
I really like it for lighting in my TT, but half of it just stopped working. I can not figure out how to access it to troubleshoot. The space between the top of the slide trim and the ceiling is only about 4 inches. I would need a mirror just to see in there.
Any ideas?
  • DarkSkySeeker wrote:
    schlep1967 wrote:
    Other option is to remove the board/trim across the front.
    Do you think there are fasteners under those end caps?
    I don't know. My slide trim doesn't have end caps. What I can see on mine is that they used something like a brad nailer to attach the trim and then used a wood putty to fill the holes. You may have to pry it off carefully which would most likely pull the nails through the back. And then use a brad nailer with nails that have brown painted heads on them to put it back up.
