lenr
Oct 05, 2019Explorer III
I use the antifreeze suction line to suck in a mixture of bleach and water. That leaves about 12" of water line from the city water connection around the valves that doesn't get exposed to the solution. I installed a new switch at the valve and city connection panel to make easy to turn the pump on and off (switch is in series with OEM switch, electrically).
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
