Geobiker's avatar
Geobiker
How to Get the Stink Out of Bathroom
We follow all the guidelines; dump when at least half full, dump the black water first and flush for 5 minutes, then the grey water, and then add the chemicals. Still within a short time, we have that dang odor again. Any ideas? Do those after market newer sewer vents (Cyclone Sewer Vents, etc.) really work and if so, any recommendations? Mind you, the odor isn't terrible, but something we would like to do without.
  • I read recently about someone that their drain pipe or vent pipe wasn't sealed where it went into the tank. Unfortunately, the way they found out was to fill the tank up and it leaked.
    Could you rig up an air hose down the vent perhaps and see if you get a burst of gasses in the rig? Maybe use a balloon full of air so there is a finite amount and no risk.
    You could also use a small tire pumped up to provide the air. Using Boyle Law, a tire at 14.7 PSI contains the original volume of air, plus one more. At 29.4 PSI the air volume is 29.4/14.7 which is two, plus the original makes three. Remember though, at 29.4 PSI you will get only two volumes out, because the original will stay in under no pressure to release.
  • If you keep some water in the toilet bowl it should seal out any gasses. If you're still getting odor you may have a leak somewhere where the odor is leaking in.
    I also pour my leftover coffee into the black tank, not the grounds just the coffee. Coffee is great at absorbing odors.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
