DrewE
May 19, 2017Explorer III
I might try foam double-stick mounting tape if you don't mind getting it on your artwork. It should come off of fiberglass gel coat with some elbow grease. If the artwork is relatively fragile when you go to unmount it, you should be able to saw through the foam part with a thin wire (preferably steel or bronze rather than copper; a guitar B or high E string might do well).
If you put some ferrous plates on the fiberglass at strategic locations, you could hang the artwork with rare earth magnets.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
