valhalla360
Oct 09, 2023Navigator
agwill wrote:
Use less water!
This. Putting 10lb in a 5lb bag never works well.
Keep in mind, the waste plumbing isn't designed to be pressurized. If you manage to plug it, good chance at some point, there will be a failure with waste water leaking into the underbelly. As you are bouncing down the road with your nicely sealed tank, the plumbing is experiencing stress and pressure from being filled.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
