daboognish88
May 10, 2018Explorer
I've already put so much money into this van fixing it up over the last three years that it'd be such a shame to just sell it (probably for way cheaper than I've spent on it). I'd like to try and save it.
Well I had a look and there is no way that I can tear out the walls to hand clean anything. The way my van is built- Its a normal Dodge Ram van which they cut the back off of and then added an extension onto the back for the bedroom. Thats where the leak is.. which I'll fix asap. And the only way to take the walls out would be to remove the entire extension which is obviously not possible.
I could just drill some holes in the wall back there and put some Mold Bomb foggers in the holes if that's feasible. I'm pretty sure all of the insulation has shriveled up which means its just an empty cavity for the fog to make its way through. After all that's done I was thinking I could fill the cavity with some sort of spray foam insulation that is mold proof. Not sure how to go about that yet either so if anyone has ideas let me know.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
