time2roll
Sep 15, 2020Nomad
I would probably pump that.
I use something like this when needed at an apartment building:
https://www.lowes.com/pd/Superior-Pump-Utility-0-25-HP-Stainless-Steel-Submersible-Utility-Pump/1000737618
As the water absorbs, note the low point to place the pump. Get some hose such as pool backwash hose to carry the water where it will run off without issue.
If this is a permanent spot where you own and control then I would be more inclined to re-slope the area as needed for a permanent solution.
This is the pump I have:
https://www.waterpumpsdirect.com/FloTec-FP0S4100X-Water-Pump/p72416.html
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
