darleyhavidson
Sep 18, 2020Explorer
JRscooby wrote:darleyhavidson wrote:magicbus wrote:
Instead of multiple smaller holes I have used a plastic trash can with holes in the side, set in a hole with gravel around the sides, and a pressure treated lid I made with a drain attached to the lid by a short piece of PVC. I put a little gravel around the drain to prevent dirt from washing in. Worked great and could handle and disperse a good deal of water in a downpour.
Dave
Fair point. My issue with digging one big hole is that if I choose the wrong spot or that spot does not absorb/drain water very well, than I am out that time and money.
I'm hard of understanding; How do you not pick the right spot? Set a laser up, find the low spot. Bury a bucket so the brim is below grade. Put a cover on it, that will let water in. A bird bath or something to mark location, keep you off it. When your lake forms, move cover, drop pump pickup in bucket run 'til standing water is gone over the hill.
I am not installing/using a sump pump. If I lived there permanently, that course of action might be more feasible.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
