darleyhavidson
Sep 18, 2020Explorer
BarneyS wrote:
I think if I were in your situation, I would try putting in some drain pipe runs out to a place where the water can flow to. Could even be the gravel filled trench already mentioned. The grass can grow over it but the drain still works.
Barney
Installing drain pipe is not ideal. The only path to direct the water goes uphill. 6 foot higher than the low spot. Not sure what gravel filled trench you are referring to, there is nothing like that on my lot.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
