JRscooby
Sep 18, 2020Explorer II
time2roll wrote:JRscooby wrote:Or just observe how the water recedes.
Set a laser up, find the low spot.
Practical low point is probably already known.
Years of pulling a enddump, I could likely eyeball the slope to find the low spot. OP worried about digging in wrong place.
darleyhavidson wrote:
I am not installing/using a sump pump. If I lived there permanently, that course of action might be more feasible.
From where I sit you have limited options;
1)Witch about it.
2)Move
3)Divert the water before it drains to your site
4)Fill area to raise grade.
5)Install a gravity flow drainage system
6)Pump water out of area.
1 is what you want to stop. 2&4 You don't want to do. 3&5 a lot of work, and much in areas you don't control.
6, once the bucket is in place, and water collects rent a 2 inch trash pump for a couple of hours. Your feet get wet on the way to get pump, and while you put suction hose in, but water is soon gone.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
