ksg5000
Dec 13, 2018Explorer II
Many RV's don't have padding under the carpet which is just stapled to the wood floor. Not sure why your carpet got wet but many would shampoo the carpet and then use combo of heat/fans to dry out the area ... if it still smells then look for wet insulation or some other issue. Normally with smells I would recommend coffee grounds etc but when smells come from dampness then you should be concerned with mold which can be harmful.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
