Lantley
Mar 24, 2018Nomad
THere is no magic pill if you really want heat you will have to supply your own energy /electric via a generator.
A 2nd battery would also be a good idea. You could get a 2000 watt portable genset and 2nd battery for $600.00 or so.
With a genset you will be fine. Without an electric source cross your fingers and hope. Your single battery may not last even 1 night.
If you don't care to invest you maybe able to rent a generator.
Be sure to use a quiet inverter genset and follow the CG genset rules whatever you do.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 07, 2026
