afidel
Mar 26, 2018Explorer II
Mainevacationer wrote:
Buy TWO fleece blankets, the good ones...not the cheap flimsy ones. Lay the first fleece blanket on top of your fitted sheet. Lay the second fleece blanket on top of the first one and then add your top sheet and regular blankets. You WILL be toasty warm! As another poster said, wear a hat to bed. I'll also add that you should change into clean underwear and socks just prior to going to bed.
Good luck.
If you're going to go this route they also should NOT be cotton, use silk, wool, or synthetics. We have scouts have miserable times on our Klondike campouts every year, the ones who listen and change into dry non-cotton undergarments before bed are not the ones getting hypothermia, whining, or leaving in the middle of the night.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
