- Dutch_12078Explorer IIIIf the dolly platform does not turn, then the key will need to be in ACC position so the steering wheel can turn freely.
- JayGeeExplorerJust to be clear you are towing the car on a dolly and not with all 4 of it's wheels on the ground?
If it is on a dolly then I would think that park would be the choice because it is front wheel drive and the front wheels will be on the dolly.
The neutral switch in acc advice must be from someone thinking you are towing it 4 down which is what you would do after following the proper setup for the transmission. - vic46ExplorerRead the owners manual under recreational towing or towing.
