rv_sailor_man's avatar
May 23, 2015
How to tow a small sailboat and an RV on a pickup truck
So I have a Ford F-150, I am in the market for an RV right now and have not decided on Fifth wheel or Travel trailer. Either way I am looking at ball park 27'. Now I want to bring a small sailboat with me, its a JY15. The specs on the sailboat are as follows:
15' long
5' 10" wide
3' tall
Weight of the hull is 275 lbs and the sails and mast and stuff can be stored in the truck and/or rv.
Is it possible to get this around with me? Suggest 5th wheel or TT or what?
They make trailers for these boats but I am thinking there might be a way to put it in the truck bed and have a TT.
  • Also you need to know the laws for the states you'll be visiting. Here in Ill-a-noyed it's illegal to double tow.
  • It's possible to do what you want with more truck or you need scale back the size of the travel trailer you wish to tow.
  • First off, whatbyoubwant to do is VERY possible. Issue I see is potential lack of payload or power in 15 series truck. Even a 25 might have issues.........but, I personally see how this can be done.
    As noted, a toy hauler with.enough garage space. A pickup with a rack correctly located. Or a boat trailer behind a 5w will also work depending upon the jurisdictions you travel thru.
    All numbers need to be wieghed along with the power requires to do the task you need to do.
    As I noted, very poster to do frankly. Not sure a 15 will do it depending upon model etc.
    Marty
  • midnightsadie wrote:
    seen a truck today with a boat on a ladder rack. the ladder rack run clear to the front of the trucks hood .
    Awesome! So far this seems like the best solution although a pain to get up there but doable for sure.
  • seen a truck today with a boat on a ladder rack. the ladder rack run clear to the front of the trucks hood .
  • Naio's avatar
    Naio
    Explorer II
    rv_sailor_man wrote:
    So I have a Ford F-150, I am in the market for an RV right now and have not decided on Fifth wheel or Travel trailer. Either way I am looking at ball park 27".
    With a 27-inch RV, I think you will be fine. Just put it in the truck bed and tow the boat. (Shades of Spinal Tap.)
    If you want a bigger RV, though, I suspect you will run into your truck's towing and/or weight limits. What are those? Can you get them off the door sticker?
    Edit: I had a Barbie class A when I was a girl... I think it was about 27 inches.
  • Also open to a sunfish instead of the JY15 but not preferred. The specs on that are as follows:
    13' 9" length
    4' 1" wide
    120 lbs
    So substantially smaller.
