ccchuck's avatar
ccchuck
HR-V Honda IS towable (FW drive only)
from the owner's manual:
"Emergency Towing
Call a professional towing service if you need to tow your vehicle.
All models
Flat bed equipment: The operator loads your vehicle on the back of a truck. This is
the best way to transport your vehicle.
2WD models
Wheel lift equipment: The tow truck uses two pivoting arms that go under the front
tires and lift them off the ground. The rear tires remain on the ground. This is an
acceptable way to tow your vehicle.
Trying to lift or tow your vehicle by the bumpers will cause serious damage. The
bumpers are not designed to support the vehicle’s weight.
Improper towing such as towing behind a motorhome or other motor vehicle can
damage the transmission."
No difference is stated between CVT models and manual transmission models.
update: THE 6 SP MANUAL MANUAL SAYS TOWABLE!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
