DiskDoctr's avatar
DiskDoctr
Humidity! How to drop 20-30% in an hour.
So we're camping this past 9 days in all kinds of weather. Heat, cool, thunderstorms, dry, you get the picture. We're in our HTT with PUGs.
Humidity was really high outside at times, which we didn't find comfortable, so here's what we did.
Turn on A/C to max to cool it down to about 70-72F. Then turn on electric heater in A/C unit (about 5200 BTUs). This is a dry heat, so is the propane furnace. (Edited per info posted by others below, propane FURNACE vents moisture to outside of camper)
Run the heater up to about 80F. The last few degrees from 78F-82F REALLY drop the humidity. Then run A/C on Max to cool it back down to low 70's.
Results? 20-30% drop in this 1 hr exercise!
We used a weather station with additional wireless outdoor sensor. We watched the temps and humidity on the indoor unit carefully while playing a game or two of Uno.
I was amazed at how quickly this worked, even with 80-90% humidity outside.
Probably some know this trick, but thought I'd share for those of us just making the 'discovery' ;)
  • Pauljdav wrote:
    The propane furnace is a dry heat because it vents all the moisture to the outside.
    I'll agree- the LP furnace is no different than an electric heater when it comes to heat and humidity- it releases zero moisture to the interior.
  • The propane furnace is a dry heat because it vents all the moisture to the outside.
  • Hey, I am impressed assuming (and I do), that it works as advertised. It is hard to beat clever. :B
  • Very good info. I have done that myself (flipped on furnace to get to 80 or so, flipped AC to cool it back down, repeated) to get humidity out. Makes the TT comfortable, not clammy.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 05, 2025
