eHoefler
Oct 05, 2016Explorer II
I would first confirm power to the pump and the ground is good. Maney times you will have a relay click, but the contacts may be carboned up and no power goes through it. Second, will holding the switch, amy need a second person, tap on the motor of the pump with a small hammer, if it starts to run, bad motor.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 26, 2026
