TheFitRV_James's avatar
Apr 11, 2014
I built a clear black tank and tested the Sewer Solution
It's exactly what it sounds like.
I constructed a clear, 20 gallon tank, with RV dump connections.
I created a recipe for simulated waste
I used the tank and the simulated waste to compare dumping with a standard 3 inch hose to dumping with the Sewer Solution.
You can see exactly what happens in the tank under each scenario.
You can find full details, and a video, here on our blog.
I tried to keep it primarily informative, but just remember that there is simulated waste in the video. ;)
I intend to use the "Black Tank Simulator" to test other products and techniques in the future. If you've got something you'd like to see tested, let me know.
As many black tank threads as I see, I hope everyone finds this helpful.
