TheFitRV_James
Apr 11, 2014Explorer
I thought about the plumbing configuration when I built it. Knowing that there are probably an infinite number of ways that a rig could be plumbed, I decided to just make things easy on myself and go straight. I thought people could just adjust the results for what they knew their plumbing configuration to be.
But I take your point. After seeing the rocket blast of water back into the tank, even a couple 45 degree elbows might change that picture significantly.
I'll have to check into modifying the setup to allow additional plumbing on the end. It's all bonded together with solvent at this point, so my options may be limited. But I'll see if I can't do something in a future run.
Thanks for the feedback!
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
