TheFitRV_James's avatar
Apr 11, 2014
I built a clear black tank and tested the Sewer Solution
It's exactly what it sounds like.
I constructed a clear, 20 gallon tank, with RV dump connections.
I created a recipe for simulated waste
I used the tank and the simulated waste to compare dumping with a standard 3 inch hose to dumping with the Sewer Solution.
You can see exactly what happens in the tank under each scenario.
You can find full details, and a video, here on our blog.
I tried to keep it primarily informative, but just remember that there is simulated waste in the video. ;)
I intend to use the "Black Tank Simulator" to test other products and techniques in the future. If you've got something you'd like to see tested, let me know.
As many black tank threads as I see, I hope everyone finds this helpful.
  • I would be glad to supply you with some non-simulated waste for further testing. a great job. when I used a sewer solution I also had a tank flush and would alternate using a Y connector between the SS and the tank flush while dumping, rather than the way you flushed your tank. and I usually got a full hook up site every third night or so while on the road so I could flush at my leisure. one thing you didn't mention was that you have a much cleaner storage of a garden hose rather than a stinky slinky.
    bumpy
