the_bear_II
Jul 02, 2018Explorer
Check to make sure your tank vents are clear on the roof. No nests or cobwebs blocking the vent opening.
Check the toilet gasket for leakage or if it's hard/brittle- replace it.
Check the vacuum breaker under the sinks to make sure it is clear.
I use Thetford Aqua-Kem deodorizer with enzymes in both the black and grey tanks. I run 2-3 gallons of water and add a packet to each tank after dumping. This allows the mixture to slosh around in the tank as we drive to our next destination or put the RV in storage.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
