dspencer's avatar
dspencer
I need some guidance on odor problem UPDATED!
I need some guidance prior to taking my camper to the RV shop. I have a 2013 Graywolf 26BH that we bought new. This problem just started this year, we're having a bad sewer smell. I use a good quality tank deodorizer and always flush with lots of water and never ever flush toilet paper down. This smell just started this year, we have never had this problem before this year.
This year we have are getting a pretty bad odor not sure if its from the gray or black tank. I will tell you i always rinse the black tank at least twice after each use and don't appear to have any blockage or anything. Any suggestions on what this may be or any suggestions on correcting this problem would be appreciated.
  • Odors happen sometimes, no seal is perfect. Could be gray or black tank, if you cook and then wash dishes, your gray tank isn't going to smell like roses.
    If you're creating a negative pressure inside the coach, like having an exhaust fan on or air conditioning on, hot outside, cold inside, but not enough windows open, nature will find someplace else to make up the air getting pulled out, including pulling it through the holding tanks.
  • But 'tank deodorizers' are suppose to 'cure' that problem
    SORRY ....being a bit sarcastic
    Where is odor concentrated?
    Have you checked if smell is coming from an Air Admittance Valve?
    (On kitchen/bathroom sink drain lines after the 'P' traps---if stay open grey tank smells come back inside rv. Grey stinks as bad/worst then black tank)
    Have you checked battery....over charging/boiling etc can stink like rotten eggs
  • I had a rotten egg smell and found it to be the water lines running to the washer hook up. I don’t have a washer but the lines had water int them and began generating a smell. I drained the lines which took care of the smell. Now the only smell I have is when my MIL comes in the trailer.
