Golden_HVAC
Sep 05, 2015Explorer
You might be able to find a replacement tank here.
Tank-Depot.com
It does sound from your description that you pressurized the tank, and might have ripped a seam open! That would be bad. If you where hooked up to 60 PSI + water pressure to the city inlet to the RV, and open a valve to fill the fresh water tank, yes you could have 60 PSI in the tank, and over a 30" X 30" sidewall of the tank, that is 900 square inches, or well over 5,000+ pounds of pressure against the sidewall of the tank!
Good luck with this problem. Start looking in all the basement compartments. Look for a panel that can be removed. It might be covered with carpet, or whatever the inside of the basement is covered with. I found them in the 'center' of the basement, over the steel chassis of the RV. This helps weight distribution a lot, so they locate two each tanks, that are 'wedge shape' so you can fit in one, then the other to the space, and take them out without disassembly of the RV.
Fred.
Tank-Depot.com
Fred.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
