nremtp143's avatar
nremtp143
6.7L CAC hose rupture..beware!
NOTE! Not trying to start a brand war of who's truck is better! Just pointing out a potential problem here!
I am posting to let you guys that have 6.7L Fords know of a problem that can leave you on the side of the road, but it is a VERY EASY fix that takes less than 5 minutes. The CAC(Cold side intake pipe) hose that comes from just inside the driver's side battery up to the throttle body can be prone to failure. A new CAC hose can be bought for around $100 shipped from the net. This CAC hose will rupture under high boost situations and the engine loses all boost pressure and you coast to the side of the road. The hose is plastic and will weaken after many heat cycles of the engine and the end at the throttle body will come apart. I carried a spare hose as a friend's left him on the side of the road just outside NYC during rush hour traffic.(because of his, i bought a spare) Mine let go weekend before last on I-85 just NE of ATL running 65mph with 22K miles on the truck. If you carry a spare, you only need a 3/8" ratchet, 10" extension and a 7/16" deep well socket and a pair of leather gloves to make the swap. The gloves are for the heat. Loosen the 7/16" spring clamp on the bottom of the hose at the charge air cooler(down beside driver's side battery) and slide the hose off. Then pull the large round spring clip from the other end at throttle body. Even when destroyed, this clip should still there. Pull off any remaining parts and wipe off the throttle body inlet to get the oil off of it. Disconnect the boost gauge wires on the side of the tube with it's quick connect. Then reverse the procedure on the install. If you have a new pipe, the throttle body end just clicks into place. You can actually be back on the road in less than 10 minutes.
IF you want to upgrade to get away from the plastic connection, both AFE and H&S Motorsports have pipes aluminum/stainless pipes that will alleviate this problem.
H&S Motorsports
AFE CAC Tube
Yep, they are expensive, but they also DO NOT require programming and bolt on to stock trucks. Thankfully, I had a spare intake tube after my friend's incident as I didn't want to be stranded somewhere with a problem I can fix in 5-10 minutes. It was a 94* day when mine let loose with my family and pets in the truck. I've just ordered the H&S for mine.
Just posted so 6.7L Ford owners will know of a potential failure that could leave them stranded.
