Ro646a
Sep 10, 2015Explorer II
I'm the OP on this thread. Thank you all for your comments and advice.
I ended up pulling out both tanks. I pressurized them both with air and found no leaks. What I did find was the drain pipe was just VERY loosely turned into the threaded port on the front tank. I was unable to see where it connected to the tank to see if that was where the leak was. Hard to explain, but apparently it was never tightened at the factory and only the pipe dope was keeping it from leaking until I accidentally overfilled the tanks and put an excessive amount of pressure on the system.
Anyway.....I was able to fix it myself. Thankfully!! :) :)
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
