Agreed, and camping I went, but I also stopped at the same scales on the way out of town just to see where I was.
The trailer pulled fine, no real wiggle or sway. In fact it pulled smoother than my old Suburban.  I always suspected I was a bit tongue heavy, and now I guess I have proof. The Suburban was basically empty with just me in it. The trailer had 40 gallons of water a few days food, some firewood and my generator.
Here are the numbers. The first column of weights is where I am currently after adding one washer. The second column is where I was last Monday. At this point I think I'm done making adjustments. I will try to move some weight off the tongue at some point since 1,000 lbs is a bit excessive. I wasn't able to restore all the weight to the front axle. But I'm thinking that is more a weakness of the stock hitch and more washers won't help.
Had to edit this post as I realized that it wasn't clear that the trailer weight was with the trailer still hooked to the hitch.
