darsben
Oct 29, 2014Explorer II
You are off by a little a gallon of propane weighs about 4.15 pounds at 60 degrees Fahrenheit most people use 4.25 lbs in a gallon.
A 30 lb tank cannot be filled over 80% if the valve is working right. 80% of 30 = 24 lbs max in the tank. 24 pounds is about 5.7 gallons + -.
5.7 gallons is less than 22 liters
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
