RoryTek's avatar
RoryTek
In need of a Coleman swamp cooler manual
Does anyone have copy of a Coleman roof mount swamp cooler? I just bought a 78' Venture 5th wheel with one on top and would just like to have a copy for reference.
I understand it has about a 4 gallon tank that you have to fill manually.
The unit looks like a standard roof mount AC unit.
Thanks all
Rory
  • the one I had years ago, the fan was direct drive, NO BELT
    it did hold several gallons of water, and was suggested to use only while parked
    it had a float valve in it, and could be connected to the RV water system
    using small clear tubing on the exterior of the RV , up to roof
    turn on pump, fill evap cooler, turn off pump, refill as needed
    drain before moving
    the filter would get dirty from the dust drawn in, being filtered and the foam filter was wet, like the mat in a residential evap unit
    fan pulled about 4 amps at 12v, 48~60w vs 1400w for 120v roof A/C
  • Not much to a evaporative cooler.
    Power source
    Fan motor....check belt--should deflective roughly 3/4". A few drops of oil if bearings have oil caps
    Fan..clean, rotates freely & oil if it has oil caps
    Pump.....suction screen clear. Water flows thru dispersing tubing onto drip trays and soaks pads
    Sufficient water level.....check routinely due to 'manual' supply
    Roof installation with manual water..I'd pickup a float valve and install it with soft copper tubing water supply line and install an over flow tube with garden hose connected to drain off to ground VS manually adding water.
    Those items available at Home Depot/Lowes/ACE
    Old swamp cooler trick........and it works
    Drop a bar of IVORY Soap in water. It helps with odor, lubes pump and helps wet pads.
    Should do well up there in the high desert.
    Lived in Baldy Mesa and only used swamp cooler for house
    Just installed one couple weeks ago in current home....house is well insulated (6" walls) and can get temp down to 68*F (85*F outside) course the humidity is about 3%
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 31, 2026
