Luke_Porter's avatar
Luke_Porter
Induction Cooktop
I see a "induction cooktop" is available in the RV I'm looking at. I don't really know what it is. Do you have one--like it a lot?
  • Not in the RV but do at home. It is one of the best purchases I have made. Almost instant heat, as much control as gas, easy clean, etc. The only drawback is that they heat the pan not the cook top. That in itself is not a problem but your pan must be made of a ferrous material such as iron or steel. No glass or aluminum unless it is stainless clad in aluminum. An easy test is that if a magnet will stick to it, it will work on induction.
  • Don't have one, but know what they are.
    It is a big AC magnet, which induces an electrical current in a metal (cast iron would be best) pot which then heats the pot internally. The cooktop itself does not get hot, although it will warm up as the pot heats it from above.
    It will not cook things in ceramic or glass pots, it requires a metal pot.
    Some folks swear by 'em.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
