wa8yxm wrote:
You need to be a touch more specific.
On my RV I use a portable Induction cooktop and it works fine on the TRUE SINE inverter or generator or shore power.
I know if I buy another TT, I will ask for a propane DELETE ! 1000w-2000W PSW inverter, probably four 6V golf cart batteries and a 2000W generator (or maybe 2) and you should be all set.
Boondocking would require some good solar and generator use for hot water and to be sure the batteries were up for the evening. Good insulation and heated mattress pad will get you through most cool nights. If you boondock below freezing, you will still need a propane furnace. Non-vented propane heaters release too much moisture to be run overnight.
