carringb
Apr 08, 2017Explorer
Lightning - a couple notes to help you get started...
1) Your van is pre-wired, including a 4-way light connector tucked into your rear bumper. The other 3 wires (brakes, battery charge, backup light) terminate in a dummy connector inside the left frame rail above the rear axle.
2) The trailer brake controller connector will be taped to the wire harness behind the parking brake. It's a brown or gray 6-pin rectangular connector. Tekonsha sells an adapter to plug right in.
3) Trailer battery charge circuit won't be live until you install the relay in the power distribution box under the hood.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
